Vararam intake
Pull Ya
Cedar Creek, Tx
Thank you
Jay
ramwad
Labelle
I am looking at getting one and don't want to jack this thread but with the paint ready option did ya'll spray paint them? I found the match for my truck and wanted to paint the cover piece the same and wanted to know if that will be good enough. I got a can of primer/color/clear and didn't know if I needed to light sand it before the primer or what steps did you take. Thanks in advance and they do look nice and I really like the look of these intakes.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Prep prep prep
I sanded, used some putty on imperfections, sanded agaiin.
Primed then wet sanded
Primed again
Taped off and sprayed black.
Dried for a couple days
Taped off black and sprayed white.
Dried a couple days
Multiple coats of clear
Take your time, use same brand of primer and paint
2012RAM1500RT
2012RAM1500RT
NC
Y
Yes Sir, Not saying what I did is right but I ordered the black wrinkle finished one, (you may decide to get the smooth finished one) and decided when I got it I wanted it the same color as my truck so I cleaned it well with purple power cleaner and wiped it down with paint thinner (be careful and test a spot inside first because it acted like it softened the plastic if you saturate the cloth, so test first) otherwise after I cleaned it I sprayed it with an aerosol plastic paint, 3 coats, no primer or clear coat. I don't know about longevity yet since it's only been 2 weeks but I'm very happy with it so far. Hope that helps you some.
ramwad
Labelle
Good points. I am going with the smooth one and all the paint came from the same place.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
2012RAM1500RT
2012RAM1500RT
NC
Thanks, I had to get them off of ebay. They are like the wing nuts that came with the big round chrome air cleaner we use to get back in the day.
