Verifying OEM trailer brake controller output voltage
aanorm69
Port Allen, LA
6.7L Cummins
I am trying to verify that my 2014 Longhorns trailer brake controller is in fact putting out the requisite 2-12 vdc. When I connect a volt meter between to neutral and brake output pin it fluctuates between 1.0 and 1.2 volts. It doesn't matter if I apply the brakes or if I manually move the paddle to the left. What is the best way to verify I am getting a changing voltage at the truck connector? Thanks
AFMoulton
Nuevo Mexico
You need a special tester. There is a thread about this issue on here, and there was a TSB, and a reprogram fix that has seemed to work. Let me see if I can find the thread
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
rcmedic
Las Cruces, NM
6.7L I6 Cummins Turbo Diesel Engine
Does anybody know if it is standard practice for FCA/Dealership to charge $76 to reprogram the trailer brake controller to make it work properly?
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Best way to test the ITBM is to connect a trailer and see if the trailer's brakes engage.
The brake controller doesn't output DC power, it provides a modulated power stream consisting of on/off pulses. The more on-time pulses equates to more output power. Google "PWM" for an in-depth understanding. The brake controller will not provide any output unless a trailer is connected. The controller senses the brake line or an inductive load to determine if trailer brakes are connected.
AFMoulton
Nuevo Mexico
Cost me 155 at my dealer to do it. So I’d say 76 is a good deal.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper Stt MAXX LT295/70R18
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Cardhu
MB CAN
If its working, it might not be displaying on your meter because the meter isn't fast enough to see the pulses. If you have a fancy one, put it on VDC PP (peak to peak) and hold on max.
