Zachary Williams
Brenham Texas
Laramie Sport 5.7 hemi 4wd
2019 laramie sport, noticed when i go @60-63 mph only my truck does the vibrating. anyone have the same issue? and know why this is happening. shes new only about 700 miles on her.
Thanks,
Zac
BWL
Embrace the skeptisism
BC Canada
Usually a vibration that only occurs at certain speeds is wheel balance related. Been in any mud. Sometimes if some get stuck on the wheel I get an out of balance vibration.
BWL
BC Canada
Anything beyond checking for something stuck on the wheel I'd just take it to the dealer with how new it is. If it's repeatable then they should be able to fix it.
Fireman48
Sc
2019 New body style
5.7. HEMI
Mine on delivery did that exactly. They took it back and re balanced the tires and now it's smooth as a babies ass.
RamCares
n/a
n/a
Thanks,
Zac
Hi Zachary,
Are you considering having your dealer address this vibration? Please let us know if you decide to do so and we would be happy to add additional assistance to this process!
Alex
Ram Social Care Specialist
Zachary Williams
Zachary Williams
Brenham Texas
Hi Zachary,
Alex
yes i will be taking it to the dealership, thank you for your concearns as well. any advice or direction is greatly appreciated
thanks,
Zac
Zachary Williams
Zachary Williams
Brenham Texas
Thank you all for your replies and Fireman48, that was my initial thought on the issue.
Again thank you all,
Zac
RamCares
n/a
n/a
thanks,
Zac
Hi Zac,
We would be happy to have a case escalated for you. If this is something you would be interested in, please send our team a private message!
Alex
Jody7
New Hampshire
I have 600 miles on mine as does the same thing. Dealer rebalanced and it continues to vibrate.
snapper23
Maybe the driveshaft is out of balance. This happened to my 94 ram. Dodge indicated that they believe the driveshaft was possibly damaged by the delivery truck. Once rebalanced and filled with sometype of spray foam the vibration went away. The vibration was at highway speeds. Good luck with a solution.
Sent from my Moto Z (2) using Tapatalk
Driver72
5.7 e-torque
Vibrations felt where? Steering wheel or some place else?
Joshua G
Peoria Az
5.7l
Depending on how long it sat on the dealerships lot, the tires may have developed flat spots. If that is the problem, there are three ways to fix it: 1- have the dealership roadforce balance the wheels/tires 2- get the tires replaced 3- continue to drive it and hopefully the tires work themselves out
rockyj69
