5th gen
  1. N
    Interior Swap List?
    Looking to do an interior upgrade on my 4th gen 1500 Laramie's interior. I've got the full center console and like it, but I like the 5th gens console better and I'd ideally be upgrading the radio to the uconnect5 system at the same time. Infotainment has the full system for the radio upgrade...
  2. B
    Passenger side rattle 2021
    I have a rattle that's driving me absolutely crazy. It's coming from my passenger side dash area. I honestly thought it was just something in one of my glove compartments, or in the door storage area. However, I've taken everything out and it's still happening. It's most noticeable when I'm...
  3. R
    5th Gen 2023 Ram | 5.7 Hemi Etorque Misfire Fix
    Hi All, I bought a 5th gen 2023 ram w/ the 5.7 Etorque earlier this year. The truck (only 10k miles) was in the shop for 38 days due to a P0306 & P0300 code. Dealership couldn't figure out problem. Dealership contacted Ram Engineers and opened a star report. The dealership was very kind to...
  4. B
    Is this normal? 2024 RAM 2500 6.4L lifters replaced at 8k miles!!
    Hey Folks - I'm seeking advice from seasoned RAM owners. I have a 2024 RAM 2500 4x4 Tradesman w/ the 6.4L gas engine. This is my first RAM truck, bought it brand new in December 2023. I took it to the dealer at 8k miles due to a slight flutter under normal acceleration, and what sounded like...
  5. C
    4th gen ram Uconnect 5 radio Upgrade
    Hello everyone I have a concern with my radio. I have a 2015 ram 1500 and it had a tradesman dash before but I since then upgraded for a Laramie dash and dash harness and everything original I also installed a UAQ 8.4 radio out of a 2019 ram classic with Apple car play and it works amazing no...
  6. Ram7081
    Looking for the blind spot monitoring harness 4th gen. Who makes them?
    As heading says. Looking for the blind spot monitoring harness for 4th gen with 5th gen tails. Who makes them? Thanks.
  7. R
    Looking at buying a 3500 opinions/experiences please!
    I’m looking to buy a 2019 ram 3500 6.7 Cummins 100k on it from a dealer, my main questions are. Reliability? How much is fair price? Which trans is better in it? common issues? And just over all general things I should look at before I pull the trigger on it! Thanks in advance!!!!!
  8. Jrico98x
    Uconnect 5 wiring harness upgrade.
    I bought a 8.4” what could be a UC5 radio and module from a 22’. I have a 21’ unconnect 3 5” non nav non Sirius xm. If someone can point me to the right direction to get the harness, I found a couple of leads in eBay, one option that could be more than certain it’s at Cali PU only, and a second...
  9. R
    Alfaobd question?
    Just tried to do a VGT sector gear hysteresis test with alfaobd and OBDlink MX+ and results show that the test is prohibited - internal Turbo Fault. Is there another/different security bypass cable needed for this test? Currently using Zautomotive's security bypass cable with white and green...
  10. R
    U11E9 Code for 2022 Ram 3500 Cummins 6.7 S.O.
    I have a 2022 Ram 3500 with the standard output 6.7L and it's throwing the U11E9 permanent code (Lost communication with AGS system). I have confirmed that the plug on the bottom of the grille shutter it self has +12v and gnd in the right places. the only other wire on it is what I believe to be...
  11. S
    Just bought my first new vehicle, 2023 RAM 1500!
    I just got a brand new 2023 Ram 1500 with the 5.7L eTorque engine. This is my first new vehicle purchase and I'm very happy with it so far. I've been watching truck prices for over a year now and saw this one advertised at just under $46,000 out the door and had to jump on it. It's a Tradesman...
  12. J
    Lowered 2022 5th Gen. IHC 3/5
    I just got my IHC 3/5 drop installed on my 2022 1500 Bighorn. I love the look of it, but to be honest the rear is a little bouncy. I also installed the airlift helper bags and am thinking the problem lies with the shocks. I am going to try to find a Bilstein replacement for the IHC supplied...
  13. M
    Passenger brake light
    I have a 2021 Ram BigHorn/Lonestar. Was leaving my buddies house the other day and he said I have a brake light out. Took it home and took off the light. What I’m not familiar with is there only being 1 plug-in. It has LED lights, and I couldn’t figure out how or why the brake light isn’t...
  14. Trey Higgins
    4th to 5th Gen Axle Swap
    So I am thinking about swapping from the 4th gen 5 lug to 5th gen 6 lug. The adapters are sketchy so I would rather do a full conversion. From my research, It appears that all I need is a 5th Gen rear axle (with the same gear ratio obviously), 5th gen hubs, and 5th gen rotors. I believe that...
  15. ISellRams22
    Done
    Debate over. Last week I installed the icon stage 2 at 3” in front and 1.5” in rear with UCA’s and new digressive coils. All Icon, loving it!
  16. Learylax3r
    2019 aftermarket LED Taillight bulb issue
    My friend purchased some LED Taillight bulbs from Diode Dynamics and while they worked originally, the tail light function stopped working. The brake lights still illuminate just fine. I helped him with the install because I have AlfaOBD. He has the security bypass module and other swapped LEDs...
  17. 1
    5th gen wheels on 4th gen?
    Thinking of buying 2020 ram 2500 wheels. Lug pattern is same, just curious if 2020 wheels would fit on a 2012 2500 backspace wise etc. ?
  18. A
    Check Engine light for active grill shutters, fan always on and loud
    Hey guys, I have a 2019 Dodge Ram with the 3.6l v6. I just woke up one morning to a check engine light. I had a computer hooked up to the obd and it threw a AGS (active grill shutter) code. I pulled everything apart and the AGS along with the whole aero system seemed to be perfectly fine. I...
  19. M
    Enabling 5th Gen 1500 (2019+ DT) Cargo Camera?
    I've seen the thread, and videos, on enabling the Cargo camera on a 2018 Ram 1500, including the mystery surrounding waiting for the Camera icon to actually show up on the head unit (Uconnect 8.4). The same AlfaOBD options exist for 2020, so I started with the ones shown there: (a) Veh Config 1...
  20. RandyMarionCDJR
    Ram 1500 Truck of the Year
    Ran across this blog post. We all (for the most part) are here to discuss our Ram trucks. Whats your favorite part about your ram? Heres the article: https://www.torquenews.com/3768/why-auto-site-chose-2022-ram-1500-top-truck-year Ram Brand Loyalty Article...
  21. Chrisjoi
    SmartCap EVO Sport for 5th Gen 6'4" Bed (Quad Cab)
    I wanted a bed topper for my 2022 Ram Quad Cab but ARE and Leer toppers are anywhere from 8 to 12 weeks out on orders. I decided to go with the SmartCap EVO Sport since the lead time was much shorter. It was more expensive than a similarly equipped fiberglass topper. With shipping I paid $4600...
  22. RandyMarionCDJR
    Bugout & Ready for War Trucks
    With the world kind of going to well.... lets just say a rough place. The question has popped up all throughout America and even in my own home, "Are we prepared when s*** really hits the fan?" Of course, being prepared is subjective to the individual but some like to go the extra mile & not...
  23. Mpgrimm2
    19-22 (19) Ram 1500 DT Laramie Grill
    Hi everyone, I have a 2019-22 5th Gen Ram 1500 DT Laramie Grill taken that was about 9mos old when it was taken off the truck. It's in very good shape with no broken or repaired tabs/mounts etc. Local pickup/meet up in Anderson/Greenville SC area ONLY (will not ship this) $300 obo **...
  24. 5
    2019-2021 stall converter 8hp75
    Who makes a 8hp75 stall converter? Has anyone else cammed their 5th gen? If so have you found a solution to this?
  25. R
    Overheating Issues
    Hey everyone. Got a 2021 Rebel 5.7 V8 and I’m experiencing overheating issues. Got the truck new with 1000 miles. At about 1500 miles it started overheating. The dealer replaced the water pump. Now at 2000 miles it’s overheating again. The fan also constantly roars obnoxiously. I’m covered by...
