J-13GTP
Back again with something that's more of an annoyance but I figured I would see what everyone thought.
So during driving when the engine is not under load and the truck is coasting it develops a slight vibration. This can happen when slow... say 30 to 45 or fast 55 to 65. If your just feathering the gas and not in it then it shows up. The vibration will go away once you get into the throttle or when brakes are applied. Another note is placing the truck into tow mode seems to help.
I'm starting to wonder if I have torque converter shudder, seems like the truck is showing the classic signs. For whats it worth the trans is a reman from Jasper which Ive heard both good and bad things about. The trans has close to 30k and all the ATF looks prefect. I know misfires can show up as the same signs but no codes are showing and I only have the torque pro app so basic info is all I have access to. I have thought about adding lube grad shudder fix which seems like a good product. The trans should still be covered under Jaspers 3year 100k mile warranty so maybe I should have a installer take a look.
Whats everyone's thoughts?
