Videos changing From H11 to H9 and from H9005 to H9011 ?
bcraig
I have looked and found Videos and Instructions on Changing the H11 bulbs to the H9 Bulbs and although some use a Dremel tool or a Razor knife to remove the Metal tabs and the Plastic Piece this Method would seem to do the Job as well?
Is this the only changes that need to be done to the H9 Bulbs to fit inside the headlight housing ?
I looked and found a Video on Changing the 2005 Bulbs to the
9011 Bulbs and found this.
Is this the Only Change that needs to be done to the H9011 Bulbs to fit inside the Headlight housing ?
Although I think the guy is talking about changing to a HIR bulb, I think that the info is revelent to changing the size of one of the plastic tabs on the H9011 bulbs to Match the size of the 2005 bulbs to insert the bulb into the housing.
I also found this video about the 9011 Bulb Modification where the guy uses side cutters and ends up splitting the bulb but then uses a small fine file and accomplishes the job.
He talks very low though and is hard to understand.https://www.youtube.com/watch?v=xaNEGW7qxH8
Will these videos cover all the changes I need to make for the
H11 to H9 Bulbs AND all the changes from H9005 to H9011 Bulbs ?
I have been skipping around different sources of information so I can do mine and thought that this information would help others as well to find this information more easily.
Brandon-w
Yukon
2015 Ram 1500
But why? Doesn't make any sense to modify that bulb when it's just as common as the rest
B
bcraig
I am not understanding your comment at all.
In this instance the Bulbs have to be modified to fit in the Headlight Housing.
What is it that does not make sense to you ?
Brandon-w
Yukon
2015 Ram 1500
Just go to the store and get the proper bulb is what I'm implying.
The H11 to H9 and 9005 to 9011 conversions are to brighter spec bulbs.
Although I wouldn't bother swapping the 9005 to a 9011 for the high beams using a halogen bulb, better to use 9005 LED bulb.
Why not just run led or hid? Seems 1000x easier.
Some people are not willing to drill holes through the housing to add HID bulbs.
As for LEDs if you live in a colder climate, headlights can freeze over due in part to the lack of infrared heat in the light.
For either HID or LED there can be compatibility issues with the CANbus monitoring that some people are not wanting to modify/change anything with the BCM. Although the CANbus error free offerings are more plentiful nowadays and actually work.
Rlaf75
East Hartford CT
2021 Bighorn
I live in New England and never had an issue with my LED's freezing over. The OP seems to be doing a lot of unnecessary work for something that has plenty of options for improving light output without being so invasive but to each their own
Brandon-w
Yukon
2015 Ram 1500
That was my thoughts. I live in the Yukon. I've never had an led freeze over issue.
RamDiver
Marlborough, Ontario Canada
2021 DS
I live in an area that has been prone to sub- zero freezing rain quite frequently during the winter months with the occasional -40°C, tossed in between.
I'm very pleased with the LED lighting in my truck. :cool:
And, I've only been flicked twice since last November and both of those were grade related, AFAIC.
That's a big improvement over the number of reactions I received with crap OEM Halogen lights in the Tundra.
photoguynorth
Canada
I bought some h11 to h9 adapter cables. Turns out the adapter socket still would not attach to an h9 bulb, but i was a lot happier taking a dremel tool to a cheap, easily replaceable adapter cable than i would have been to cut the actual truck connectors. Also, that let me do all the modifications at a table rather than in the garage.
The H9s are significantly brighter than stock. Not like HID or LED, but until i get around to buying full LED projector assemblies I get better light, low cost and zero chance of CANBUS errors. Also less chance of glare for oncoming traffic.
Daw14
South Florida
Link for cables ?
photoguynorth
Canada
Link for cables ?
I did not originally post the link because I am in Canada, so it was amazon.ca. also since I had to modify them there may be a better adapter available. With that said, here is what I bought:
Edit for clarity, I know that is not actually an H9 adapter, but i thought from what i could find that it was the same connector.
If you change the .ca to .com,it usually sends you to the same product on the US site.
