View BU Cam While Not In Reverse on 8.4
g00fy
Cummins 6.7
I searched the forums didn't come up with anything, I have a very small ATV trailer that gets lost behind the tailgate and with my old truck the Pioneer Radio had a button to view the Back Up Cam while not in reverse so i could check on everything. Is there a way to do this on the Uconnect 8.4? Thanks.
1500ram12
5.9L Cummins
You would probably have to use a lockpick or jailbreak device
Sent from my VS985 4G using Tapatalk
1500ram12
5.9L Cummins
Or you may be able to install a switch that would fool the radio to think you're in reverse and going under 5mph.
baum
savage, mn
2015 Laramie
sorry you cant. the radios are canbus controlled so the cam is not actually activated by a reverse trigger
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Google ... CustomTronix
They have a sw jailbreak that will do it and you can add extra cameras (backup, Cargo/3rd brake, front)
Or Lockpik as mentioned.
Sent from my LG G4 on Tapatalk.
posttal
Cleveland , Ohio
2011 and 2013 Laramie
I have a lockpick and can view my rear camera when ever I want....that's the only way your going to do it since the factory view gets its power for the camera off the back up light circuit....where as the lock pic generates its own voltage to the camera
