Viper 300ESP Alarm Install 02 1500 Questions?
Savatreatabvr
Phoenix
I'm trying to install a Viper alarm in my truck but can't find a good ignition wiring diagram. I'm just using the ignition/starter interrupt but I don't know which wire under the dash to cut. Any help with diagrams or experience would be great!
Fast69Mopar
If you want to interrupt the starter circuit, look at the connector at the ignition switch. Remove the steering column upper and lower shrouds. Pin #13 Yellow wire is the starter relay circuit. If you connect here and arm the alarm this will disable the starter relay from operating.
S
Savatreatabvr
Phoenix
AWESOME! Thank you so much. So I guess I'll just T-Tap the wire?
