Warning 101
Bowpope54
Centre,Al
Truck died. Jump off windshield wiper and washer came on. No radio or anything else on black screen. Just a warning 101 not used. Any help would be appreciated
tron67j
Maryland
Is any working in your truck, as in does it crank, do headlights or fan come in? What were you doing when it died? Did you replace battery lately?
My first step, without knowing too much else, would be to do a load test on your battery to check the amps. A voltmeter won't tell you much.
markabby
Monticello, Kentucky
2020 Limited
glad you understood that..all i could tell was dead battery
B
Bowpope54
Centre,Al
Bought new battery. Cranked but battery emblem on. Someone told me that it’s probably alternator. No blinkers no backup camera.
tron67j
Maryland
You need to load test the battery, and checking output of alternator would also be a piece of the puzzle. Your truck is 12 years old. Things happen. I would check all main power wires, clean contacts and check for any loose fitting contacts. Also check main grounds. And verify all fuses, relays, etc. are good and seated properly. Even a new battery can be bad, it happens.
RickH
Connecticut
I had a similar type of situation a few years ago when charging was intermittent or not working and finally traced it to several bad grounds under my hood. Start at the battery and work your way out, removing, cleaning and refastening as many as needed to overcome the problem, and/or, do as others have suggested. It worked for me. I hope it helps you. Good luck!
Marshall
Sk, Canada
2014 sport
Has not happened for a few yrs, but I have bought battery's that where not charged up from sitting on a shelf for a long time, so I usally would put a charger on them, yrs ago a low charge was not a big deal, these days ,its a big deal with all the computers in these things.
