Water Getting in from Passenger A Pillar
Chefgordiemac
North Carolina
I have water literally dripping out of the upper bolt cover of the passenger A pillar. Had this looked at twice and was told condensation from the high mount brake light. Was supposedly fixed. Any ideas?
Is there any recall or manufacturer repair available?
Thanks
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
Condensation from the high mount brake light isn't a thing. If there's water coming from that area it's because the 3rd brake light is allowing water to get into the cab (leaking). This is a common issue. There is a warranty extension for some 5th gens, but I'm not aware of anything like that for 4th gens. I'm coming from the 5th gen world, but the problem can be addressed the same way on a 4th gen. Replace the 3rd brake light. Replace the 3rd brake light gasket. Seal the 3rd brake light to the truck with RTV. I wouldn't opt for the last option myself but others have gone that route.
C
Chefgordiemac
North Carolina
Thanks but I'm not sure what you mean by the "high mount brake light isn't a thing" Can you clarify, please? Thanks
CanuckRam1313
Ontario Canada
2023 Warlock
I combatted this by removing the third brake light and cleaning the areas with a microfiber and alcohol.
I replaced the existing third bake light gasket with a new OEM one.
I then laid down a small bead of RTV weatherproof sealant on the body side and let it set/cure properly.
I then installed the third brake light assembly (new OEM gasket mates with the fresh bead on the body side of the truck to form a tight seal that allows the third brake light to be removed at a later date with zero issues) and screwed it in place evenly.
Zero issues afterwards! ;)
Whilst doing this, I also installed two new LED super bright white cab lights and an even brighter red LED brake light bulb, too (all CanBus/Resistor ready so I don't get any dash messages...lol).
The light output is amazing, and Stevie Wonder could see my brake light now as well :) (there are some dumb ****'s out there, and making oneself more visible, especially when braking is paramount, IMPO).
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I removed the factory seal and replaced it with home weather stripping I had laying around like this (separated into one strip instead of the two pictured).
No leaks in 8 years...a question though, do you have a sunroof? That's a long way for the water to flow and not exactly the path of least resistance. Usually when the water is coming from the third brake light folks find the water on the rear headliner and under the rear seat.
1999 White C5 Coupe
mikeru
Super Moderator
2020 Limited
I prefaced what you quoted with "condensation from the". The amount of moisture that might condense inside the 3rd brake light wouldn't fill a thimble.
Dodge 1500 4X4
Rochester, NY
Let's talk about water intrusion first of all the A pillar is on the driver's side behind the fender, passenger side is D pillar. Is water leaking onto the drivers side floor board, there is a TSB out for the A pillar, water from the CHMBL will get you a wet headliner, if you have a wet floorboard behind rear seat it could cracked slider window frame or leaking cab vents?
Jas34
SC
There seems to be some pillar confusion in this thread. A-pillar is next to the windshield, B-pillar is between the doors if you have a truck with 4 of them, C-pillar is at the back of the cab. If only 2 doors, then that's the B-pillar. There's a left side A-pillar and a right side A-pillar, etc.
Assuming the op has leak at the C-pillar, as others mentioned, it's likely the 3rd brake light or the cab vents behind the seat. No recall or anything, but there is a redesigned vent that looks like it will seal better long term. I have a pair of them ordered for my truck but they seem to be very slow in coming in. There's also a thread somewhere in these forums where others have had good luck replacing the stock foam gasket on the 3rd brake light with MD auto and marine weather strip.
One trick we used to use to find water leaks was to close the vehicle up with the blower on high (not on recirc), put soapy water on the suspect places and look for bubbles. Not sure if the cab vents in this truck work well enough to keep the cab from pressurizing. If so, covering them would help.
If the "A" pillar grab handle is where your water seepage is,
then i would say the moisture is coming from a Sunroof or roof cab lights.
The last places would be a leaking Windshield or a ROOF SEAM
If on the other hand, you water is entering at the rear cab wall up high..
3rd Brake light is the most likely entry point
possibly the rear sliding window or cracked Frame
or a leaking roof seam
if the water is entering low on the rear of the cab, again the rear sliding window drains could be plugged.
Lastly, the rear cab vents can allow water to entry, the water entering there, could ruin the RF Hub that is mounted behind the seats, next to the vents, the first sign of water entry would likely be seen in the carpeting
Good Luck
mikeru
Super Moderator
2020 Limited
The A pillar is the farthest forward on both sides of a vehicle, and is not different for the passenger side. Quad cab and crew cab trucks have A, B, and C pillars. Regular cab trucks have A and B pillars. We don't have D pillars. A vehicle like a station wagon and many SUV's would have D pillars.
Sauerwal
I pulled back my headliner on my 2021 RAM 1500 and found water on the rear pillar. I have had mold smells off and on since I bought my truck used last year. Did you figure out where the water is getting in?20251104_134353.jpg20251104_134347.jpg20251104_134353.jpg20251104_134347.jpg
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I pulled back my headliner on my 2021 RAM 1500 and found water on the rear pillar. I have had mold smells off and on since I bought my truck used last year. Did you figure out where the water is getting in?View attachment 575524View attachment 575525View attachment 575524View attachment 575525
That looks like driver's side c pillar. If so I'd remove the antenna from the roof inspect and clean the gasket, maybe even put some silicone (grease?) on it and tighten it back down.
Daw14
South Florida
Remove the third brake light from the rear center of the roof . Inspect inside for evidence of it leaking , you will see where water has ran and dust and dirt pooled.
Go to a hardware store and purchase some appropriate size weatherstripping that can take the place of the thin factory gasket.
Sauerwal
Thanks for the quick reply! I will try that. I had heard they could leak around there but didn't see any evidence that is where it was coming from. Would a bead of outdoor clear silicone sealant work?
Sauerwal
I had pulled the headliner down to bring my shark fin inside the cab so I can fit in some downtown parking garages. I used a plug kit on the antenna hole along with a little silicone. I think if I go and hit the third brake light that should stop any risk of water getting in. Is there any other things that can cause water intrusion on those pillars?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Not to my knowledge unless you have a sunroof, but that's typically A-Pillar water problems. You can replace the sharkfin with the puck antenna and only loose cellular reception but keep SXM and GPS
Glowz
