water leak 1st gen 360 sb
bpowell22
5.9 L 360
I have a water leak at the left side rear of the motor. I can see the water coming from a small hole in the rear of the engine block above the starter. The hole appears to be about 3/4 inch in diameter. Is this a freeze plug port that may have blown out? Any help will be appreciated. Thanks
RonJon '06
Southern Minnesota
If coolant is leaking out then its likely a rusty and corroded freeze plug. I've only replaced the larger 1 5/8" ones which isn't too bad of a job. Welcome to RF.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
^I concur with the above statement.
Also welcome to RF.
