weird clunk
JMikk
5.2L 318
hey everyone, recently as i was driving after recovering from being ill i noticed a new sound from my truck while driving. Its almost as if a stick it being dragged along metal bars, i dont know if you did that as a bored kid but i did when i walked around places. its coming from the right front so it cant be my front diff or the sound would be from the left. Could it be a wheel bearing or something worse? cant test the bearing right now because my jack doesnt work.
J
JMikk
5.2L 318
Check out the front axel u joint.
you know the u joint was loose the last i checked it, just kind of never thought anything of it. figured it would last a little longer
J
JMikk
5.2L 318
It shouldnt move any.
I know i was just hoping it would last till i get my new job and then i could spend the money to get a more pricey part since i take the truck off road. cheap parts are most times weak parts and i dont want to break any more of them.
Merc225hp
NA
truck
gas
That u joint lets loose u will be spending some big coin on axle shafts.
bassslayer25
East, Kansas
5.9 360 V8
When you do go to replace the u joint you might as well do the other u joint and the ball joints too. You don't want to skimp out on components like those.
Gr8bawana
6.7 CTD
Could be something as simple as the scraper on the front pads telling you it's time for new pads up front.
Raadz
