Weird Noises
David Janes
Iowa
3.0 Diesel
Any ideas as to what could be causing the tick/rattle?
Brandon-w
Yukon
2015 Ram 1500
Sounds like normal injector tick to me.
Elevated 2013
Huntley, IL
I agree with Brandon unless you hear it more when the engine is cold??
Ohio5pt7
Ohio
Sounds like injectors. You can always throw in some redline or royal purple 5w30 and if it goes away or reduces you know it was your valve train.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
PENNZOIL MARINE PREMIUM PLUS 2-CYCLE SYNTHETIC BLEND with fuel-ups helps tame injector noise.
TheEnder
4.7L V8
This is the first time i’ve ever heard an engine that sounds somewhat like mine on cold starts. I do believe it’s a injector that’s on its way out. Although mines a far bit louder.
Sent from my Blue Onyx RAM 1500
Elevated 2013
Huntley, IL
There are 2 things you can try that I know of. 1) Seafoam. 2) a can of Molybdenum that I found at Auto Zone in a gray can that says it can be added to the fuel. I can say that Mopar fuel injectors can be louder than some other manufacturers injectors and it’s normal.
David Janes
David Janes
Iowa
3.0 Diesel
Thats the red can of seafoam your talking about right? Just throw it right in the gas?
David Janes
David Janes
Iowa
3.0 Diesel
I would hope its not an injector I haven't even rolled over 70k miles yet I'm 200 miles away from 69k (had to add that in there lol)
Nice thing is if something goes I have complete coverage until I think 112k miles!
David Janes
David Janes
Iowa
3.0 Diesel
@Brandon-w @Elevated 2013 I hear it more when its just started. Sometimes I will get a awkward rattle in there with it as well which was in the video just tough to hear. I also hear it as I start to accelerate it gets faster and a little louder but then gets quieter when the engine gets to operating temp
Ohio5pt7
Ohio
Injectors on these trucks are loud to start. I have a vararam intake so it allows more noise than normal since I removed the cover.
Elevated 2013
Huntley, IL
Do you hear it more on 1 side of the engine than the other? Might want to chance all of your exhaust manifold bolts and heat shields on the exhaust. Especially if you hear it more at idle than when you’re cruising along.
Ohio5pt7
Ohio
@Ohio5pt7 don't think its anything to worry about?
Injector noise no. Even some valvetrain noise isnt a huge concern unless it gets super noticeable. Mine started its hemi tick @ 10k switched to royal purple 5w30 and it's gone. 50k now no issues. I still hear my injectors though.
David Janes
David Janes
Iowa
3.0 Diesel
Is that something where you can just ask the shop to use that oil instead? Don't hate me but I haven't learned how to change my own oil yet.
David Janes
David Janes
Iowa
3.0 Diesel
Ill make sure to listen on the passenger side. I just hear it when I get into my truck. Never really go to the other side lol
Ohio5pt7
Ohio
Never seen a shop that will actually put any oil in besides what is recommended by the manufacturer. You may be able to ask but definitely dont ask your dealer.
David Janes
David Janes
Iowa
3.0 Diesel
Nice thing about my shop is that they do a lot of performance/aftermarket stuff that is not street legal so I wouldn't be surprised that he would do it. They are awesome
TheEnder
4.7L V8
This, injectors on these trucks are VERY loud on cold starts. It’s normal and nothing to worry about.
joshhhh
