Well then
Brandon-w
Yukon
2015 Ram 1500
Ouchie! I'd send yoy my luck but it'd probly make it worse
Dodge 1500 4X4
Rochester, NY
What are the symptoms, how do you know you bent a connecting rod, usually the fuel gets past the rings and into the crankcase, I would do a compression test on the cylinder with the bad injector.
D
dhmadden01
Clarksville TN
3.6L
Crank with no start and I heard it went it bent. Now it dound like a mad small person banging on the inside of my block with a hammer
Jeepwalker
WI
2012 Reg Cab, 4x4
Well.... maybe you can (if lucky) just replace the rod/piston. (???)
What's your gameplan?
D
dhmadden01
Clarksville TN
3.6L
T
Try to come up with 5k to buy a used motor and put in it. It's my only way back and forth to work and I'm in a loaner for now but I'm not sure how long that's gonna last
jws123
nj
T
How is it 5k for a used engine? Your not at a dealer are you? i see engines range from 1500-2k plus id imagine 1k for a install.
D
dhmadden01
Clarksville TN
3.6L
2900 for one that's in state with 130k plus 2k taking the old one out and put the used one in and the core charge
jws123
nj
No core charge as long as you return the old engine. also 2k for 130k engine is to much
also look on facebook marketplace for engines you can hear them running if its in a wreck always good deals.
