what are your opinions on this mod?
AWE Daniel
Banned
Too scared to do that one with mine. I baby my tranny lol
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I have the TMR mod and the line boost. No big deal, just adding pieces to complete the package. IMO, each mod compliments the others.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I have that mod along with the shift kit that beefs up the valve body alill. You can pick up the Transgo kit for alill over 60 now I think from Summit.
HKkid
Missouri
Also interested in this as well. Are the shifts any faster?
lilfroger
5.9 CTD
..beefs up the valve body...
That should be a requirement for anything that builds line pressures.
Do a Valve Body job at the same time and you'll notice the most gains and protect yourself in the long run.
More line pressure is going to lend itself to firmer shifts and less slippage of the packs.
OklaHemi
OklaHemi
new age hemi
so if i do this i should do the trans go kit at the same time?
lilfroger
5.9 CTD
With as much as ATF costs ... do it all at once :)
No in all seriousness ... if you are going to modify anything with in the trans ... do all the supporting trans mods at once. Otherwise you are going to create a 'weak-link' and find yourself in a pickle.
Tackle the TC, VB, pressure all at once.
OklaHemi
OklaHemi
new age hemi
ken did you install it yourself or have it done? if you had it done what was the cost
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I did it myself with my bro while we did the motor. We didnt put the ring on the plate but pulling the valve body is easy. Just unplug the elec connector and drop the pan then drop the VB. Its bout 35-45 min job tops. At part throttle its alill stiffer at WOT you can deff tell a difference.
OklaHemi
OklaHemi
new age hemi
my little brother is ase certified and his father in law owns a transmission shop. i usually use his shop to do stuff but i have never worked on a transmission at all. i may have my bro there for guidance.
