What caused this?
soapy
Northwest
6.4 hemi
A week ago I started my truck and now when ever it revs to over 2000 rpms it starts roaring making loud sound like it is sucking for air. It never did this before. It does it with or without the AC on, tranny in neutral or park. As soon as it shifts the engine is quiet again. The dealer has no idea what it is.
St. Charles, AR.
Do you have a cold air intake? If so this will be normal. If you have the factory air intake just check all of the connections. (Throttle body, hose going into air box, cap on air box, etc.). If any of these are loose it could be the culprit.
smurfs_of_war
Swift Current, Saskatchewan
I'd bet money it's your fans going full tilt and a sensor is possibly out of sorts. Mine roar pretty good when I start it for the first time on a hot day then they shut up.
granite14
Portland, OR
2014 Ram 2500, 4x4, CC, SLT Big Horn
So only when in neutral and park when you rev it over 2000?
I'd guess its the fan clutch is engaging because you are not moving, therefore since you are revving the temp would be increasing, it would need more air to cool. Once you set off to drive it would not need the cooling, as when you are shifting, I'm assuming you are at idle rpm and not over 2000?
