1SloRam
Love brake buster, especially in the ik sprayers, p&s is class all the way.P&S makes a good product. A lot of my buddies in the industry use them.
Which of the pod light brackets did you go with? I am also thinking of getting a set to throw an antenna on.Finished up the Auxbeam switch panel wiring, and added some Diode Dynamic lumens. Still need to run the wire to the rear for the manual reverse light switch, and I left open spots for front bumper lights and a light bar, both of which will probably wait until I get an aftermarket front bumper. Also next mod I have working is a gmrs radio with the antenna going on the light mounts also.
Got the word today that TruckGear(Line_X) is sending a new cover. Love the lifetime warranty. Over 2 yrs old. Hopefully with this one some ********* won't put something on it and scuff it up at the storeWe are having some hellish winds today, gusts to 72. Went onto the highway and bang and seen the rearview mirror go black. Looks like the wind was perfect angle to mess with it and it broke loose from 2 of the 6 "tabs" that holds the top to the rails. Luckily I got the lifetime warranty, now for the fun of dealing with them.
I went with these from SDHQ in AZ, little spendy but they are rock solid and don't use the hood side hinge mount like most of the others, so they sit further back and don't go up and down with the hood.Which of the pod light brackets did you go with? I am also thinking of getting a set to throw an antenna on.
sdhqoffroad.com
www.nhoverland.com
FireStik makes a super low profile connector . I used these on the Jeep for a tight mounting location. and if you get the 2-pc FireRing, the radio side connector separates so that you can feed it through a smaller opening.I went with these from SDHQ in AZ, little spendy but they are rock solid and don't use the hood side hinge mount like most of the others, so they sit further back and don't go up and down with the hood.
https://sdhqoffroad.com/collections...00-dodge-ram-sdhq-built-a-pillar-light-mounts
I added a set of these for the side ditch lights, I had to drill them out for the mounting bolt but it works well.
SDHQ Built A-Pillar Add A Light Mount Kit for Baja Designs Squadron Series Lights
Our SDHQ Built A-Pillar Add A Light Mount Kit for Baja Designs Squadron Series Lights is designed for individuals who have purchased a set of our a-pillar bracketssdhqoffroad.com
I also picked up the @NH Overland antenna adapter, I just don't have it put on yet since I haven't picked up the radio.
Ditch Light Extension Antenna Mount
Ditch Light Extension Antenna Mount will give you a semi permanent mounting location for the antenna of your radio 3/8" mounting hole to accept most ditch light brackets For NMO connector Raw Aluminum or Black Made in the USA.www.nhoverland.com
Nice looking cable, I'm likely going GMRS and Midland makes a similar cable for the NMO mount here:FireStik makes a super low profile connector . I used these on the Jeep for a tight mounting location. and if you get the 2-pc FireRing, the radio side connector separates so that you can feed it through a smaller opening.
click on the coax, fitting and Misc button on the left. The site is not all that high tech
midlandusa.com
@Quick_ShifterHey guys,
Many have mentioned Quick-Shifter in Marcus Hook PA. Does anyone have their number? I have search a lot to find them but nowhere to be found. Im looking for good Ram diesel shop willing to install Banks products. from NJ
thanks
On Instagram ak_trucks_pa Definitely worth contacting, I’m in Va & his is the only shop I’ll trust with my truck.Hey guys,
thanks
You’re an inspiration,kinda like the gas tank fuel pump video i saw this morning.Changed the shift solenoid and filters on my ‘13 Ram 1500 after getting the p7050 light. Found one of the valve body bolts in the pan when I dropped it, lol. Bought the truck used.
Was able to protect the brand new driveway from 7qts of fluid with a giant tarp successfully. Truck works again!
