Kid's HEMI! !!
Upgraded the original 8.4 head unit in my 2015 2500 to a CarPlay unit out of a 2018 RAM.
was that fairly straightforward to do just by the head unit and just plug it in or did you have to buy something else with it? I’ve been looking at changing mine and I was considering getting one of those Tesla style ones but I’m hesitant on it.
Kid's HEMI! !!
OK the fun is over with for now now it’s time for some much-needed maintenance. Just ordered B&m transmission pan.
Gwerner74
NC
The head unit itself was a direct plug and play, no special programming needed. You will need to upgrade the USB Media Hub in your armrest because the one in our trucks aren't compatible with the CarPlay units.
I had a Linkswell Gen 4 T-Style in my truck for a couple years, it started acting squirrely so I went back to stock. I have to say that even before it started acting up it really wasn't worth it IMO. Whatever app you're using only fills half the screen and even though you could do split screen for a couple different apps, you would have to set it up every time you turned on the truck, there was no way to save it as a setting. The other pain was the climate controls, you'd have to wait until the unit fully boots up to do anything with the heat or AC. The big screen looked nice in the dash but that's pretty much the only positive thing I can say about. Much happier now with the stock look and CarPlay.
nlambert182
Huntsville, AL
I finally installed replacement switches (heated/cooled seats, exhaust brake, etc..) from where my 8.4 Uconnect screen leaked. While I was in there, I went ahead and swapped in a new screen as well. Much better!
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
Not mine, but my dad's '14. After I told him about my moisture issues and doing my cab vents/rear seat mod, he checked his truck and had 3" of water in the rear wells. So we did his cab vents, 3rd brake light seal and the rear seat mod. His cab vents only had 1 flap left on the driver's side and 3 on the pass side. He'd also had a small amount of water seeping into his headliner.
Heathen-19
Midwest
Did the Big 3 upgrade. Bought a kit off eBay. Gave me an excuse to buy some large gauge wire cutters and a hammer crimp.
PA Ram
Quakertown, PA
Finally got around to putting my new shocks on that I bought a few months ago. I know most here are Bilstein fans, but man these adjustable Rancho RS9000XLs ride nice. I had spacers on the front for leveling,but didn't like the way it reacted. The struts I got have 2 inch levelling so no need for a spacer. Have the fronts set to 5 and rear at 6 to test to see where I need them set. May set them stiffer for towing the camper,but probably don't need to since I put airbags on the rear.
Hemi395
Cape Cod MA
Nice!
I did that too, the factory grounds in these trucks are adequate at best
Black-Wolf
North Carolina
Welp... I attempted to replace the lower ball joint on the passenger side. I replaced the driver's side one a couple of weeks ago, but weather and other commitments have prevented me from doing the passenger side. Today - I had no issues UNTIL I got to where I was trying to separate the steering knuckle from the hub... WHOEVER designed this needs to be put out to pasture. The ball joint is apparently corrosion welded to the aluminum knuckle, and I can't get it out. I've tried several different pry tools, a ball joint separator (which didn't fit - it only goes to 2" wide and I need one that can go at least 2-3/4" wide to fit over it and the knuckle), and pretty much cursed it, yelled at it, smacked it with three different size hammers, used a pickle fork on it, lubed it with penetrating oil, and cursed and yelled at it some more. It refuses to budge. I've given up for the moment. I have a better ball joint separator arriving tomorrow EVENING - but I don't think I'll have time to work the problem before it gets dark... Needless to say, I am beyond frustrated. I do NOT have a blow torch to try heating it and letting it cool while beating it with a hammer. As of right now, my truck is not driveable, even if I put everything back together, the ball joint is completely shot and needs to be replaced. Some pics for entertainment of the little B*STRD.
marine0311
Ohio
I took delivery of my new to me beautiful '15 Ram 1500 Laramie yesterday. over 24hrs later my wife and myself still have smiles on our faces. This baby is awesome!!!
aszumilo
Las Vegas
Changed plugs and coils. Took about 3 hours, give or take. Passenger was a lot easier than the drivers side. It was easier than doing it on my old 2004 Ram 1500. Looks like original plugs were never replaced. Had The NGK coppers in it. Switched them out for Autolite Platinums. Old plugs wer so worn, the gap was .060 or greater. Swapped the coils out for some cheap aftermarket ones, until I can afford some new OEM ones. Computer throwing codes on 2 of them. Seems like my misfire is gone from just revving in the driveway. Haven't taken it for a drive yet, because sister brought some pizza over.
Hemi395
Cape Cod MA
View attachment 538254View attachment 538256View attachment 538255View attachment 538257
Oh man that sucks!
Mine are getting some play in them and this scares me :eek:
Keep us updated how things go tomorrow night.....
Stefan N
Sweden
2015 Sport
I used this ball press and it worked ok for removal, a bit harder without the right adapters when pressing in the new one.
Starter kit I used: https://otctools.com/products/ball-joint-service-kit
OTC tools says this is the right kit for our trucks: https://otctools.com/products/chryslermitsubishi-truck-ball-joint-adapter-set
I still have right side to do too...
BenWade
Houston
It is much simpler and quicker to just replace the lower control arm that already has the ball joint pre-installed.
Hemi395
Cape Cod MA
Agreed its much easier. Get an alignment and you're good.
However it sounds like @Black-Wolf is having problems getting the old ball joint to separate from the knuckle...
Black-Wolf
North Carolina
Not the issue. Still would have to get the ball joint to separate from the steering knuckle - and THAT's where I'm stuck at - it won't let go. You still can't replace the LCAs until you get the ball joint out of the knuckle.
Black-Wolf
North Carolina
I have a ball joint press... the problem is getting the ball joint shaft end out of the steering knuckle. The driveshaft is in the way of trying to use a regular press. The separators I have borrowed or bought are all too small for the size ball joint and knuckle thickness - measured it and it's 2.75" from the top side of where the ball joint shaft goes in the knuckle, to the bottom of the ball joint shaft. The normal ball joint presses only reach a maximum width of 2" or 2.375". The cheap Chinese crap I bought on shamazon might work because despite what the ad says, the center body of it has 3.3" of depth/clearance, and I think I can finagle it into position and use constant pressure and striking to free the joint. If not - I'm going to have to cut it out somehow. Here's the link to the product: Amazon
Hemi395
Cape Cod MA
Let me know if this works, I'm ordering it if it does
