What do you run your tires at?
MarkV
Ontario, Canada
4.7 Magnum V8 NOW with Moose Power
What PSI are you guys running you tires at? I have 275/60R20 and they say max 50 psi.
What do you think i should run them at?
charonblk07
Calgary, Ab
F1-A forged 349ci
Run them at the pressure listed on your door, which should be 35-40psi. The vehicle's suspension is designed to work with the compression of the tire, running max pressure you end up with the same results as if you move to a stiffer sidewall like an e-range; you put more on the shocks/springs and you get a harsher ride.
MarkV
MarkV
Ontario, Canada
My sticker says 35psi for 265/70R17....
hotkarl
4.7 Semi-Hemi
I prefer a firm ride, not harsh but not squishy.
I tend to go over the sticker by a few but never to maximum inflation.
Explit Player
Bristol, TN
Haha I have 35x12.5s, and it feels like I'm driving with concrete tires. They're wide and anything below 55 makes them look flat.. So I have to run 70rear, 75front(wear issues) to keep those things inflated correctly, and wearing even... Not a soft ride
