1. engine light comes on. shutter code ...
Shutter code? As in the active grille shutters? What’s wrong with it? Or better yet, delete it unless you decide to get the dealer to replace it under warranty since it’s a 19- or are you already over 36,000 miles? If you are, do you a quick little web search. There’s a pretty cheap kit out there that allows you to simply delete that active grill shutter system. Maybe you should look into it.
2. radio comes and goes. no fix.
I highly doubt that. If your current dealer can’t find it, take it to another one. If that one don’t work, take it to another one.
3.display only works when it wants to and sometimes stays on for a mile or 2
See answer to number 2.
4. factory tires only lasted about 20000 miles and that was front tires
Ever had your alignment checked? You know, it is possible that they could’ve not set it right at the factory. But if that’s all good, it’s funny how a lot of people actually get a lot more miles out of those factory goodyears than just 20,000 miles except for those people who basically take a street tire and they go off road on it or they’re taking corners hard, taking off like Jack rabbits and slamming on the brakes every time they stop.
My old 2008 that I had before my new one, had 29,000 miles on it when I bought it and the tires were just barely under half worn out and they were the same tires that you got.....or well, had, or whatever.
5. when slowing down its like it shifts into neutral and revs up high and kicks back into gear
Refer again to answer given to #2.
6. fuel pump went out and they don’t make the new one yet.
Huh? So then where are they coming up with all the ones that they’re putting in the brand new trucks?
all issues addressed with dealership and of course none of them would happen when the dealership had it 2019 Laramie 1500.
Again...... refer to answer given to number two. But you mean to tell me but all those problems, including your worn out tires wouldn’t present themselves when you took it to the dealer? Hmmm. Interesting.
