what size gears
Ramsfan78
St. Peters, Missouri
HEMI 5.7
I would like to find out what size gears my truck has. I bought it used and I cant find this anywhere. I don't really want to go taking things apart to count teeth or whatever and there is no sticker on the diff cover. So my question is, is there a way to look it up by the VIN or is there a sticker somewhere that I could look for? I went to Home : Free VIN Decoder - Vehicle Identification Number Check and put in my VIN and it told me a lot about the truck but nothing that I didn't already know. Also, I have seen the trick about putting a piece of tape on the tire and the driveshaft, etc. Just wondering if there an easier way.
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Request a build sheet from Chrysler. Check the link below. I got my build sheet emailed to me and they sent a paper copy to me a few days later.
Contact Dodge
Simply put in the notes that you are requesting a copy of your trucks build sheet.
JohnnyDollar
Texas Hill Country
I also bought my truck used.
Besides the build sheet (which took about a week to get),
there are also a couple of other things you can do:
1) Crawl under the truck, on mine there is a white tag on the axle that shows the gear ratio.
There is also a metal tag on the differential with the ratio stamped in it.
2) You can register your truck at https://www.moparownerconnect.com/oc/US/en-us/sub/Pages/OwnersLogin.aspx.
You can access the same info as your build sheet (Learn & Use section) and also check recalls (needed and performed), dealer performed maintenance - Mine shows the oil changes done by the previous owner (date and mileage)
ETA: Problem is, being used, if the previous owner swapped out the gears and did not change the tags, you might have to do some more work.
If you floor it from a dead stop and you barely chirp, you probably have 3.55's. If you floor it and it chirps almost every time, 3.92's outside chance it is the 3.73. If you gun it from a dead stop and you are toasting them and you have to take your foot out of it, 4,10's. It is very scientific way to find out. Another way is if you are getting good gas mileage, it is definitely 3.55's.
derek_m
You can always just call the parts department of your dealer give em the vin # and they can tell you what gears your truck has
PCA4208
Albuquerque, New Mexico
And if I do it.. I'll make nice stripes on the road..
4.56 gears haha.
Yeah baby yeah, I woulda said that but I doubt he has 4.56's.
Ramsfan78
Ramsfan78
HEMI 5.7
Booooo. I got 3.55. Found out from the build sheet. Well, I guess add that to the ever growing list of mods. Ha.
