what sway links to get for 2.5 leveling kit?
demo401
5.9 gas 4x4
Hello dodgers. So iu put a 2.5 leveling kit the other day and all kinds of things started going. Ujoints, bushings, so i need new sway bar links to start off. Being that its 2.5" higher idk what links to get? Rock auto an dautozone have different sizes but im new to my truck so im stumped. Can someone provide me a link or what proper size links i need? Not trying to break the bank neither
OccupyDean
5.9 Magnum
I'd look for some drop brackets and go from there. 2.5 is not a huge amount once you get over 3 you really wanna look for different ends.
Johnn123
Ontario
I wouldnt worry about dropping anything at 2.5". Youll be fine without. Nowadays I generally just recommend going to the parts store and getting something with a life time warranty.
D
demo401
5.9 gas 4x4
so does that mean i should run regular links as if i dont have the 2.5? newbie here
Johnn123
Ontario
It is doable
If your links are OK I would run them till they wear out
The level will accelerate the wear
Sway bar drop brackets are an option as well
Best way to put it. Most dont really worry about it though.
96DodgeRam4x4
5.9 Magnum
chances are your front end components were already worn before the level. at 2.5" its not gonna wear that quick just because of the level. Ive seen people say they've had problems and some have run theirs with no problem for years. Just depends on truck and how you use it.
D
demo401
5.9 gas 4x4
i dont do any woods or mudding/offRoading i just put the kit because my 35"s would fit with my plow attached
D
demo401
5.9 gas 4x4
when i 1st bought it it was stock wheels them i bought 36 swampers and it almost shredded my fender and bumprs off. Took them off then got 35s. They rubbed a little then i got the 2.5 leveling kit installed so its good now.
