What the heck is this?
BadHemi2014
Greater Cincinnati area
Ok I'm so glad you asked that because I never knew what that was lol.
Thanks guys for your collective wisdom!
Gr8bawana
6.7 CTD
I broke that thing just a couple of days after getting my truck because I just can't leave stuff alone. :shrug:
I thought it was a button to open the little square thing around it.
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
:laughing1:
At first i thought that it might be a Proximity Sensor, but the other mirror would have the same thing on it
I never liked the ambient temperature sensor in the driver's side mirror, it is always incorrect, because it is surrounded by hot plastic, reflective glass from the side window & a metal door
The engineers must not have studied how temperature gauges work
When you mount an outside temp gauge on a tree, you are supposed to mount it above the tree trunk at the line of where the leaves begin & the breeze can pass over it.
Before they mounted them in the mirror, they mounted them behind the grille & off to the drivers side of the radiator & condenser fins & the temp gauge reading was real close to correct
atc06jh
Middle Georgia
Just wait until you do a quick car wash and it’s 93 outside and the gauge says 68. It’s going to blow your mind. Then the water clears and it goes back to normal.
kong79
South Eastern Nebraska
Very true. I was always amazed at how accurate it was and the reading never seemed to be affected by baking in the sun. The new mirror mount-not so amazed.
VA-RAM
STL, MO - Norfolk, VA
2017 Laramie / 2020 Laramie
The remote start antenna is behind the back seat on the drivers side near the vent
It is called a RF Module
Is this the same RF antenna/module that provides the signal for the proximity sensor to unlock the door when you grab it and to lock when you push the button on the handle?
From what i understand, the RF Module is what allows the FOB or RKE to function
Fun Facts:
FOB is short for FOBIK = Frequency Operated Button Ignition Key
RKE = Remote Keyless Entry
Scrounger
Charlotte nc
2019 2500 mega cab 4x4
6.7 I6 Cummins
Its a light for when your backing a trailer, button is at bottom of light knob below fog light button
