What transfer case fluid do i need?
hemi1300
Columbus, Ohio
Went to the dealer today to get spark plugs and some other crap to do the typical maintenance on the truck this weekend. Gonna change the transfer case fluid and thought they all used atf+4 tranny fluid? Dealer said he needed my vin to see what it called for, bought the atf+4 anyway. Apparently, one of the transfer cases uses a special fluid, not sure though. Will i be safe with normal mopar atf+4?
Sent from my DROIDX using Tapatalk 2
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
ATF+4 according to the DIY thread on fluid changes.
hemi1300
hemi1300
Columbus, Ohio
Ok, thought so, thank you
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I think the reason dealer said this is the transfer case with Auto 4wd which is in Sport and higher 1500's uses something different.
$miley
hemi1300
hemi1300
Columbus, Ohio
That makes sense, my truck just has the typical 4x4 shift knob on the dash so atf+4 should do it
