What's the Correct Oil Pressure for a 3.6 V6 in a 2020 Ram 1500?
Revchuck38
Southwest Louisiana
V6
I did a search and everything that came up was about various versions of the Hemi.
My engine's oil pressure according to the gauge on the dashboard runs ~20 psi at idle and ~40 psi at highway speed when the oil is at normal temperature (~200-220 degrees). I'm using 5W20 but am considering going to 5W30 since the engine has 98k miles on it. Is my current oil pressure about where it's supposed to be? I bought the truck new and it's been consistently in the same ballpark. It's not currently using any oil.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I feel like my 2014 idles around 28 but highway is definitely around 40.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
July 2020, 0w20, oil temp 224, 16 psi at idle. I switched to 5w30 & add a 15 oz. bottle of Lubegard. Today 226 at idle 24 psi pressure.
16 seams really low, 24 is much better. Is 0w20 the OEM spec for your truck, if so what year?
gfh77665
SE TX
2019 Classic
3.6 Pentastar
The rule of thumb for minimal oil pressure is 10 psi/1000 rpms. If you have at least 10 psi at idle and 20 psi at cruising speed, you are good. Of course a bit more would be better, 20 at idle and 40 at cruising is perfect.
