whats this part?
maple
San Bernardino CA
So i was adding some aux switches to my truck tonight and thought i found the perfect spot to put them... i was wrong and messed upthe little panel under the light ***. Anyone know this part number so i can order a new one?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Subscribed
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Eye balled the **** out of it lol plus there's a lever or pull Handle behind that panel for something. Its in the way of the switches so they stick out :superhack:
That's exactly what happened to me. I used a rubber grommet to give the switch more backspace. I've looked for a part number, but have had no success.
The piece you see behind it is the manual release (neutral switch) for the electronic 8-Speed transmission. You pull it out prior to being towed. If you try to leave the truck in neutral (or drive or reverse) from the shifter, the truck automatically puts it in park when you try to turn the truck off.
All of the guys saying its the perfect place to mount a switch don't have the 8-Speed...
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
Take the picture to you dealer parts person, he will identify it for you.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
That pull handle releases your Tranny if you loss power.
Sent from my SM-G900V using Tapatalk
