wheel bearing or cv joints
dripley
hickory, nc
2002 2500 ho 6 speed 4X4
5.9 24v cummins
my wife has an 06 dakota 4X4. i am hearing a roaring noise from the left front wheel. i is speed constant and does not change with transmission shifts. i have jacked up the front end and have no movement side to side or top to bottom while puling on the wheel. the ball joints on the left are going out. i did have up and down movement on the left only when prying up on the tire. any time i have heard this noise on other vehicle it has been the bearings.
this is the first vehicle i have had with cv joints so i dont know alot about them. there is no clicking noise. i backed the truck up with the wheels cut all the way to both sides and nothing. is ther something else in there that i need to check. the noise is getting worse and something is gonna give sooner or later. your help would be apprciated.
ramhunter9
P-Star Jeep Wrangler
Sounds like bearings to me , try this ... spray them down with WD40 and see if they still make noise . If so .. you might be able to just re pack them .
But might also be the ball joint telling you REPLACE ME .
quietpeen
2021 TRX
Hellcat
aren't dakota's notorious for going through ball joints?
ramhunter9
Yes just like the ram 1500s
I would spray them to be sure
dripley
dripley
hickory, nc
5.9 24v cummins
i know i have got to replace the ball joints on the left side, already got them at the house. ill spray them and see what happens. thanks
