wheel spacer help...........
shawnwhite78
heres the plan guys 14 ram qc 4x4 with 3in front coil spacer ,1.5 rear coil spacer with stock 20 inch wheels that I want throw 35x12.5x20s on, so the question is what size wheel spacer is needed and what is a good brand?
S
shawnwhite78
Perfect, thanks for the info I appreciate it, what size lift/ level kit did you go with and brand? Any chance of you sending me a pic?
Shawn
S
shawnwhite78
All done with the 3 inch front and 1.5 rear spacers installed the 35s On the stock 20s WITHOUT using a wheel spacer. Not sure if it will work for everyone but it works for me.
smarsmar101
Waterford. CT
99% if the time, all you need is a level and a 1/4 spacer to run 35's on factory offset wheels.
S
shawnwhite78
Guess I got lucky and dont need the wheel spacers
