Wheel weight ratings
audio1der
Airdrie, Alberta
Does this help? (EDIT- file type was too large and didn't attach)
Diller
Nashville TN
6.7 HO Cummins
Not sure what you are going for but I am 100% certain they are well above any axle or GVWR limit.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
I wouldn't say that...the wheels on my 97 dually (dana 80 axle) were only rated for 2350 each or close, which means 9400 total....Dana rates the axle at 11,000 lbs, but Dodge rates it @ 7500 lbs......how does that work ???
The tires I had on it were rated for 3200 lbs each.........
loveracing1988
Clarkston, MI
GVWR is the most the total vehicle and payload can weigh, not how much the axle's can hold. So if the gvwr of your truck was 9400 lbs or lower the rims are rated just fine.
TRCM
USN, Retired
Newport News, VA
I know what GVWR stands for.......GVWR was 10,500
and why would you put rims on an axle if they can't handle all the weight the axle can ??
answer: to make sure you don't have to worry about warranty claims...I mean why else would dodge derate the axle from the 11,000 dana rates it at down to 7500 in the truck ??
loveracing1988
Clarkston, MI
To be fair the axle can alone handle more than the entire weight of the vehicle being overloaded since it is rated for 11k. If you saw how much force it actually takes to yield an axle like a 3500 has in it it would scare you.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Interesting I am sure most people reach tire limit before rim or axle limit anyway.
KAKA
