Where do you jack from
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Just wanted to start a thread about the jacking spots on our 2nd gen's because I've seen it done many different way..
A few places I've herd is the front cross member in front of the oil pan
Under the front axel pumpkin
Under front axel hosting on either side of the tires
What do you use as your "safe" jacking points? :)
Lethalweapon100
NY
V8 5.9 Magnum
Yep, under the diffs or on the axles is always my first choice. Both with the jack and the jack stands. I always try to put the jack stands on the axles, reasonably spaced out for max stability. My frame is too high to jack from.
