Which Brake Fluid for 2012?
Jeepwalker
WI
2012 Reg Cab, 4x4
Hi.
The manual says Dot 3, same as the master cylinder. I assume it's just regular brake fluid, right? Didn't read anything about synthetic fluid.
Lastly, I pretty much have been using the same brake fluid for years, but is there such a thing as incompatibility issues between different brands?
Thanks,
grizzstang
Calgary, Alberta Canada
It will say on the bottle. My manual says DOT 3 recommended but DOT 4 is acceptable. You should be able to find DOT 3 easily and I never had any compatibility issues using a decent brake fluid. Would there by any way to know what brand of brake fluid is in it anyway?
J
Jeepwalker
WI
2012 Reg Cab, 4x4
Not really. I just bought the truck from a dealer that was a trade-in. From papers I found floating around inside, the previous owner owned it about 2 yrs. Both were independent dealers. The fluid looks pretty fresh actually.
