Which coolant
indept
South Jersey
Some evaporation is normal as is the need to occasionally add a small amount to the overflow reservoir.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 062044 miles.
Not much though. I bought my truck new Sept 2017, I have 38k miles and my antifreeze is still at the full mark. I never added any.
jackdashack
USA East Coast
1500 Hemi 5.7
OAT the color options can be confusing. Just an example Prestone makes a universal OAT that is like a yellow green. They then have a universal platinum now as well which is 15yr/300,000 mile while regular one was 10 yr/300,000 then they even have an orange OAT for North American. I emailed them as I find this to be very stupid. I personally use the Prestone universal concentrate and mix it myself 50:50. I use this in every vehicle I maintain. From GMs to Dodge to Ram. It works perfect.
Some even say Coagulant free. Just make sure it is OAT and I doubt you would ever have an issue. As far as warranty you will see Prestone universal is made to become whatever color it is mixed with on their site. I don’t think they could have done a worse job making coolant options confusing.
Smiley hello! I have a 2013 1500 Hemi 5.7 Bought new I only have 35k on it. I was told last oil change it was a little low on anti/cool. I have an unopened gallon here. And knowing nothing I have asked and get confused from answers. But one pointed me to this thread. This gallon is from Advance Auto and I poured some out to see the actual color. It's yellow green. And then I noticed on the label [Compare to Prestone Antifreeze/Coolant. Do you think I have the same as the Prestone you use. And is it necessary to mix it or is it premixed? Thanks!
I think 13 was a cross over year as far as coolant goes.You might be wise to go to your local dealer with your VIN number and see what coolant your truck has,because mixing the wrong coolants could cost you a bunch of money down the road. Buy a gallon jug of their pre-mix and you should be good for a few years .Just my opinion though
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
It is safest to use the Peak global lifetime but frankly the universal stuff won’t coagulate so it would matter. Just make sure it isn’t the traditional green. If it was me and I wasn’t sure I would get Peak Global lifetime then it doesn’t matter what is in there. My 14 is OAT.
jackdashack
USA East Coast
1500 Hemi 5.7
thank you. This I topped off with, I guess fingers crossed as I've crossed a lot of info here, was Prestone yellow-greenish in an Advance Auto bottle. Says on the side, Compare with Prestone. And on the back they made a statement that they used CAPS the word ANY 3 times, ANY make, ANY model, mix with ANY antifreeze . . . sounds universal to me. But to be sure I won't use it anymore. I might have even bought it since I bought the Ram 8 years ago telling them what I was driving, and this is what they gave me. I just don't remember the purchase. But it couldn't have been for my last vehicle, a Jeep Wrangler. It had to be the type for this Ram. In any case thanks! ":-Dx
LouM
Marine Corps
Greeenwich/Easton upstate NY
2015 Ram Ecodiesel crewcab old/ 2019 Laramie Hemi old/ 2022 RAM 2500 6.7
eco diesel old / now Hemi missing the eco's mileage/ now back to enjoying diesel torqueesel
I see that there are two currently running threads on coolants,
I post this on this one also.
Just for information, I apparently mixed coolants in my SxS.
It took me considerable time money and work to get it cleaned out and working again.
inside the water pump cover
what was left of the old impeller and the new impellor.
Not a fun few days.
And then not long after I got that fixed my daughter called me her mini van was over heating and no one knew why then she tells me a neighbor had put some coolant in for her because she was low. That made for a road trip to NC and a couple of days of flushing and blowing out a cooling system. Hers had just turned to a slimy jelly like substance thast actually cleaned out decently with lots of soap and a bit of chemical flushes and air pressure.
In 70 years I have only been directly involved in two instances but that was 2 to many.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
That is probably from traditional green mixed with new age HOAT or OAT. The whole topic makes my head spin. Sad really.
slickracer
PA
2018 Big Horn Crew Cab
I'm trying to figure out why my 2018 5.7 has orange coolant from the factory, yet the recommended coolant is the purple 150,000. What do I use when it's time for a drain and fill?
LouM
Marine Corps
Some of the MoPar coolants will change color with use. I wouldn't stick my neck out and recommend any.
Except to flush / clean and flush some more and then use the recommended coolant or which ever one you prefer.
buckeyexx
Ohio
2016 Power Wagon
Are they not all marked and say what to use on the reservoir cap? My 2015 2500 has OAT on the cap of the tank.
Octane
U S.A.
The best argument concerning buying from the dealership is confirmed by all the confusion the antifreeze companies have caused.I buy mopar online and it's maybe only a dollar or so cheaper than the dealer.Ships free to my door.And it makes me and my Mopar do the Happy dance.
Hemi395
Cape Cod MA
The 10 year OAT will change color to a pinkish orange after a while, totally normal. Your truck being a 2018 is the 10 year OAT, as far as I know it's only the early 2013s that we're questionable.
Octane
U S.A.
When I bought my 13 Challenger and my 13 Ram the dealer told me that all 2013 vin numbers used the 10 year stuff.But I know they make mistakes about their own products more than likely.
Sherman Bird
Houston, Texas
Not a fun few days.
My step daughter was in college years ago.... drove a 1997 Saturn SL-1. It sported Dex-Cool pink coolant. She went up to her Dad's in Rural Central North Texas. As a favor to her, he checked her fluid levels and topped off the coolant with green. That turned the coolant into a peanut butter consistency. In those days, I used Oxalic acid to clean it out. It worked like a charm. Dontcha know that the EPA outlawed this acid for automotive use since then! I can get it at the hardware store nowadays. It's sold for use in wood finishing. I do know that a LOT of baking soda and massive numbers of gallons of water are required to neutralize this acid after use, lest it eat aluminum cylinder head, head gasket, etc. A few moths later, I did have to replace the radiator, but that was due to the cheesy plastic tank giving out from age/mileage.
Burla
2010 Hemi Reg Cab 4x4
Update on very cool development, prestone max has several choices of coolant, one is a ram ten year coolant clone, the sds shows pure base and it's purple. Maybe even better then mopar coolant, because mopar coolant has to use short term additives to protect young metal, but once metal is aged and protected, all you need is base, and this product is pure base.
This is not HOAT, it is OAT. So if you are early 4 gen like me, you might want to stick with 5 year hoat from mopar.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
OAT began with ALL Mopar passenger vehicles for the 2013 model year, if you have a 2013 or newer you need to run only the OAT and this is the dealer stuff.
MS 12106
Some info on Page 12
someone mentioned that what is in the radiator seems to be sort of Orange
Take something like a turkey baster
draw out some of cooled off Orange coolant
drip it onto clear glass or a bottle
in sun light, i think you will see that the liquid is purplish
nascar72
Canada
It is horrible. They make you doubt yourself and it just sucks. I am thinking a lot of it has to do with everyone wanting to get money for certifications. I would trust Prestone universal in anything. Looks like on their site they also make autozone and super tech too.
I have an '08 2500 with the 5.7 that I bought in 2021 with 110k km (70k miles) and as soon as I had the chance, beside oil change, did complete coolant flush and refilled it with a 70/30 Prestone universal coolant and distillled water. And 40k km later, (25k miles), no issues whatsoever. Did same thing with my '03 1500 5.7 and my '05 Chevy Blazer. Never had any issues with any of my vehicles that I replaced the OEM coolant with Prestone universal coolant. But everytime I do a coolant flush I make sure that there isn't any trace of the old coolant left in there. Basically I flush until it comes out clear.
Sherman Bird
Houston, Texas
