Ok thanks, just wanted to make sure because I bought these bulbs:
THESE are the low profile ones.Ok thanks, just wanted to make sure because I bought these bulbs:
In their default settings, they fit perfectly. The low beams are clocked at 9 and 3; the high beams are clocked at 12 and 6. When I adjust the high beams to 9 and 3, they block the ability to install the dust covers.
I'll order different bulbs.
Yep, I read all of your posts about them before deciding which ones to go with. My projectors are 9005 and 9012. I was really worried about the whole 2015 drama with LED's, but these bulbs and the AlfaOBD tweaks I've had ZERO issues. Thank you to all your info on them!That's a great set of LED bulbs similar to the first set I bought. I donated the H11s to a friend after discovering the projector housings on my truck use 4 9005s.
The Fahren description used to have a picture indicating the actual measurement size of the bulb package but for some odd reason, they no longer provide that detail.
This is from an older Fahren advert on Amazon.
Yeah they were fine, but I really didn't spend any time analyzing the high beam light spread. So I'm curious if I notice a difference with whatever I get next.How is the light spread with the high beams clocked to 12 & 6?
AFAIK, the purpose of clocking to 9 & 3 is primarily for the low beams to contain annoying oncoming traffic.
If the light dispersion provides descent illumination of the roadway from the driver's perspective, and the high beams are never used while following or with oncoming traffic, who cares where they're clocked?
I have Fahren low beams clocked to 9 & 3 and older Auxito bulbs that weren't adjustable.
IIRC, one is 5 & 11 and the other is 7 & 1. Both sets of LED bulbs are awesome.
Cool. My interest is having the bulbs clocked correctly, so I swapped them out for these:If you have the time and interest to R&R bulbs in your Ram, have at it and report your findings here. I monkeyed around briefly with mine and after a few R&R sessions, I can't be bothered anymore.
I just set them straight to HID after reading through all the posts on the 15's. Didn't wanna take any chances.You're most welcome, glad I could help with your successful upgrade.
Did you have to set the headlights to HID with AlfaOBD or was the LED setting sufficient?
I'm still pleased as can be with the Fahren bulbs and the after-sales support from the manufacturer has been just short of spectacular.
