Which rear shocks to go with ?
Rams88
Thunder bay Ontario
I recently installed a zone 4 inch lift with the 2 inch spacers in the rear in my 2016 1500. The shocks that came with the lift are garbage and I'm looking to replace them. I'm just wondering what would be the best option to go with?
DILLIGAF
Canadian Forces
Canada
6112s Front / 5125 Rear thats what I run on my 4" lift
crazykid1994
Yes bilstein 5160 should be. I’m not sure about 5125? The 5160 extended length is good for 1 to 2.5” rear lift and I run them on my truck at 1.25” rear lift and they’re great. Planning on swapping to 6112 fronts soon to around 2-2.5 on my truck from 5100s soon too
Bilstein 5160 extended length
RamMan381
I originally went with bilstein’s “5100” all the way around on my 2016. In less than 60,000 miles all of them have failed. Had the same issue on my wife’s jeep. They look pretty but they are cheap pos shocks. They “bilstein” literally state that it’s normal for the 5100 series t to leak oil….. bilstein does make some fine products but the 5100 series is not one of them.
I have had amazing luck with FOX shocks.
Zoe Saldana
california
6.4l
Look at the Ranco 9000XL - you might like the ajustability.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Send @Nick@GotExhaust a note. He’ll set you up with fox 2.0’s
