RoadKing
Okay. I have tried two different harnesses with module to add remote start to my 2013 Ram Express.
First one I got from Doug on Ebay. Had the XPress something module. Would not work.
Second harness is Flash Logic.
Apparently with the OEM stick Key the module should program, my Flashlogic had the wrong firmware so it did not work.
But with the correct firmware it should.
And then I should have remote start using the OEM stick key. But once the lock button is pressed three times to start the truck the OEM stick key becomes in-op. Meaning I can then not use it to unlock the doors. I could pull the spare key out of the remote to manually unlock the door, but who wants to do that.
So Flashlogic sells RF remotes to use in conjunction with the OEM stick key. Which means I would be carrying two key FOBs. Not a huge deal but rather prefer carrying one. Well I could keep the OEM stick key in the truck and just put the key in the ignition when I get in each time.
Which is what I will probably do.
Anyway I am trying to decide which after market remote key fob to use.
Has anyone used Flashlogic FLRF1, 2 or 4?
The other one comes with the Viper kit 4105n or 4205.
Thanks.
Thanks.
