Which tires will not vibrate? 35x12.5r20
DA Smith
Marshall Texas
What do you mean by cupping? So I installed the lift myself last week. Lift is installed correctly and everything’s tight. I purchased these tires used from a guy I know. Got them cheap that’s why I bought them. Didn’t know about cupping though. These tires have only been on my truck 2 days. I kept my original tires just in case this happened and I guess I’m going back to original for a while.
There's your answer to your issue ...... bought them cheap from a guy. The guy sold them cheap because he was unloading a bunch of crap !
turkeybird56
Central Texas
^^^ DITTO ^^^ OP: Put your tires back on and/or get all new tires, mounted properly, etc and alignment done.
YUP, and improper rotating and not enuf air pressure or in this case, looks like to much PSI, do it real quick (cupping, and bad quality tires). I actually check the PSI on my AT3W's every 2 weeks with a digital gauge, to make sure proper inflation, but just what I do. All only IMHO .....
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Cupping can also be caused by suspension parts that are worn out not just incorrect psi on the tires ....
turkeybird56
Central Texas
Yeah dat too, lol. I just did not want to get all the way down in the dirt, but buying someone's used tires to put on my truck (my DD), ahhhh, hmmmmmm, interesting experiment for sure.
Hal Brown
Ponca city ok
I learned the hard way. When changing things up essentially lifting, always check pinion angles. When the arcs of the ujoints scribe different angles it can definitely cause vibration. I had a bandit trans am I put a Moser rear end in with fiberglass springs different transmission and I tried 7 ways to Sunday to stop it with no luck. I was ready to sell it,I was so ticked off. I sent the whole rear end back to moser to check, checked my new wheels for true hub centric,got a carbon fiber driveshaft,balanced on several machines among other things. Then I stumbled on an article about pinion angles. It worked perfectly. I was on my knees giving thanks afterword. Yours may be fine but it's easy to check. Sorry about the long post but it brought back strong memories.
Danny Phillips
Payson AZ
I put a set of Hercules M/t's on my truck. They are a little noisy now not so bad when new. I wanted the Patagonia's but could not get them at the time. They seem to have good traction off road and on the highway. Next time I'll hold out for the Patagonia's.
Dannycameo
Calgary
How much lift did you install? If it was over 2" you'd messed with the steering geometry.
You need or should get an alignment after a lift.
As somebody else recommended go with the Mickey Thompson baja boss AT.
Or if you want a mud terrain go with the BFG KM3.
And make darn sure they are balanced.
T
Txlonghor1n0
Houston
Are you clearing 35x12.5’s on those factory wheels with no wheel spacers? And you are 2WD, correct?
Truck looks great!
Thanks! Yes these are 35x12.5 nitto ridge grapplers on the OEM 8” wheel. It’s a 7 inch lift from maxtrac. However, I am currently converting it back down into a 4.5 inch lift. I’ll post pictures tomorrow.
T
Txlonghor1n0
Houston
Yeah I installed a carrier bearing drop down bracket but 7 inches is still extreme. I have a 2 piece drive shaft and they’re a couple of degrees off of each other at 7 inches. That’s being said.. I removed a pillow block off the back end yesterday and I’m reinstalling my OEM shocks tomorrow. Essentially lowering the truck from 7 inches back down to 4.5 inches. It solved the driveshaft issue.
T
Txlonghor1n0
Houston
Here’s the truck after lowering the rear back down. I’ll post the front complete after I finish tomorrow. The angle was just too close for comfort for me at 7 inches. I like this better. Also at 7 inches this would barely fit in my standard 7 feet tall garage! It cleared in by about 4mm. If I pulled in too fast I would of scraped. Lowering it down a few “ will eliminate me having to be so careful pulling in and out. 6751ED58-ADB7-4882-B8FA-C3707DBC4C3E.jpeg2104AD33-C6CF-44DB-A276-215267BC0FE5.jpeg
OC455
Central NY
Here’s the truck after lowering the rear back down. I’ll post the front complete after I finish tomorrow. The angle was just too close for comfort for me at 7 inches. I like this better. Also at 7 inches this would barely fit in my standard 7 feet tall garage! It cleared in by about 4mm. If I pulled in too fast I would of scraped. Lowering it down a few “ will eliminate me having to be so careful pulling in and out. View attachment 499375View attachment 499374
I think dropping it is a good idea, driveshaft issues and the like...
I spy a Viper in the stable there...NICE!
T
Txlonghor1n0
Houston
Haha good eye! A 2004. Great car. The truck drives much better at 4.5 inches. It also clears the 35 inch tires with no rubbing.
TheRamdalorian
Fort Worth, TX
That guy screwed you, bro. Those tires are only 200 a piece anyway brand new. Check out Milestar Patagonia m/t. I paid 1500 for a whole set of 37s and they're excellent. SUPER quiet, quietest tire I've run because of their design. They are a crowned tire, so they're designed to have a little curve on top. You do not want the tire resting flat on the pavement. Rotate them every 3-5k miles and you're good to go. Best quietest tire I've ever run, quieter than the stock FIrestones this newest Ram came with.
mvm2
