Who has a 2014 that is leveled?
sawbillslayer
How did you level it and have you had any problems ? Thanks....
lokal907ryder
wasilla, AK
I have a 2014 sport with the bilstien 5100's set @2.1 and the zone upper control arms. Only a few thousand miles so far but no issues.
hotrodderscott
2014 CC5 I actually use my truck as a truck so I liked it to sit a little higher in the rear so when i have a load on or hauling it sits level for this reason I went with Icon 1.5" progressive rate springs in the rear and Rancho 9000's
But more importantly and what your concerned with is the front...
I went with Rancho quick lift 2.25" they use a heavier spring rate but NO spacer. The factory and Ranch strut are exact same length!!!
GREAT ride and 3K NO ISSUES! !!
Hayn
3.6 vvt
I have a 2014 1500 4x4 with ranchi quick lift and rs9000xl in the rear for about 9 mos and no problems the truck actually rides better than stock
MADDOG
Living in a Firepit
2014 2500CC 6.4L with a 2" level. No problems.
Klaus96
Illinois
2014 2500 CC Laramie 4x4
Maxtrac 2.5" 2 piece spacer system.
Factory UCA's
No issues
3" PA Body Lift
RamWagon
Bils at 2.8 for about a month now. Zero issues
Ecklund
Calgary, Alberta
I have the same set up , but I get a vibration when driving over a 100kmh. Did you feel this at all with your truck?
jsteinm1
Nebraska
2014 Ram 1500 Sport CC
HEMI 5.7L
Bils @ 2.1, stock UCAs. No problems so far, 5k miles in. I don't do any off-roading, but I do go over some rough train tracks daily to/from work.
henryhemi
Gainesville, Fl
I have a 2014 with bilsteins maxed out at 2.75". Also have 1.5" poly spacers on the rear springs. No issues at all. Rides smooth no vibes. Stock control arms btw.
cajun87
Louisiana
Got 2" hbs level with welded uca's on my outdoorsman for a year now and no issues.
Hemi395
Cape Cod MA
I agree with and second both these statements. I was shocked at how well my truck rode after leveling with Ranchos. Ride is better than stock.
atc06jh
Middle Georgia
I have a 2WD. I got the Mevotech UCAs and TopGunz 2.5" level spacers. Been on there for a few months now and no issues at all.
dbrock34
Started with the 2.5" Rough Country with the 1.75" rear spacer. I wasn't happy with the ride at all so after 17k miles I replaced the front 2.5" with Bilsteins set at 2.8 and left the rear spacer in. The ride is soooo much better now and after 11k miles on the Bilsteins, still no issues.
Arturo Rojas
