why???
razor1
St.Petersburg Fl
Installed factory powder coated 22" wheels, new tires, new TPMS's.Every thing was great for 3 days then no connection to all sensors. They tried resetting then, I disconnected the battery for 30 minutes. They can't see the sensors with the portable tool, nothing. Help!IMG_2643[1].JPGIMG_2639[1].JPG nothing.
RamDiver
Marlborough, Ontario Canada
2021 DS
What type of TPMS sensors were used, and did the tire vendor/installer supply them?
If they were supplied by the installer, that sounds like their problem to sort out.
If the portable tester can't see them, I wouldn't expect the RF hub to work any better.
razor1
razor1
St.Petersburg Fl
mopar parts, I installed the sensors before taking them to get tires . Sensors are positioned correctly.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Don't know why they can't see them with tool, any of them? Can't for the life of me believe the new ones would all die at the same time.
If you have AlfaOBD, try doing a reset on the RF hub.
1st clear the TPMS Audit
2nd: Do sensor rolls test
3rd: Reset RF hub
That fixed my TPMS problems after I changed the Spare tire TPM with an Autel 2 in 1 MX sensor.
Have this Autel 501TPMS tool and it works awesome.
