Will it Fit?
styl721
Panama City, FL.
4.7L
I put a Rough Country 3 in suspension lift on my 2006 dodge ram 1500 2wd will 17in rims with 35's fit correctly or No?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Provided the wheels are the correct width and offset, yes. But we can't give you a definitely answer without knowing those specs.
S
styl721
Panama City, FL.
4.7L
i know the width is 12.50 and the stocks that i have now are that with i was wonding as far as if the 3 in suspension lift will lift me up enough to run 35"s on 17' rims
brandonjansen
With stock 17's you'll need 10mm hubcentric spacers from Motorsport Tech to run the 35x12.5's. Other than that you're good clearance wise.
geneseedennis
