Will these fit on a 2 inch dropped rear with stock front ride height
M3AN ONE
Long Island
Im looking for off road tires that will fit on 22 inch rims with stock ride height in the front and 2 inch drop in the rear. Im looking for something that will involve no rubbing. The question is will these below fit?
33/12.5/22 Nitto Ridge Grapplers
M
M3AN ONE
Long Island
Decided to go with Toyo open country AT 3 285/50/R22 that way I wont have to worry about rubbing or them sticking out too far past the fenders and they stand almost a inch higher than the Nittos I was looking at.
M
M3AN ONE
Long Island
I have been doing some research and from what I see 285/55/22 (34.5 inch diameter tires) such as Ridge Graplers and Open Country AT 3's will fit no problem since the width is less than 12 inches even though I am running stock ride height with 2 inch drop in the rear. But all I have been reading is on 35's you may need to upgrade the differential gearing from a 3.2 to 3.9 . I dont want to upgrade my dif (currently running 3.2) and I also dont want the car to become too sluggish. I understand the tires are heavier but wondering if I can get away with 285 since its not a true 35 inch tire also E rate not F also not as heavy. So the question is should I stay with the idea all things considered of getting a 285/50/22 (33.6 inch tire) or 285/55/22 (34.5 inch tire)? 33's weigh around 56lbs 34's weigh 63lbs.
*Excuse my ignorance if I got anything wrong I learned all this yesterday by binge watching Nito and Toyo Ram 1500 tire YouTube vids.
Johnnguyen6596
