Will this combo work?
Marrapode
5.7L HEMI V8
I'm not the best when it comes to wheel and tire combinations. Had a piece of rebar blow through my tire on the highway today, so I figured it's time for an upgrade now haha. If someone could help me out that'd be great! Thanks
MOTO METALMO962
GENERAL GRABBER A/TX
  • Size: 265/70R17
  • Service Description: 115T
  • Load Range: SL
  • UTQG: 640 A B
  • Max Load: 2,679 lbs
  • Max Inflation Pressure: 44 psi
  • Tread Depth: 14/32"
  • Tire Weight: 44 lbs
  • Rim Width Range: 7-9"
  • Measured Rim Width: 8"
  • Section Width: 10.7"
  • Tread Width: 7.2"
  • Overall Diameter: 31.6"
kurek
Northwest
The factory 17x8" wheels that were available on 3rd and 4th gen (interchangeable) 1500's have an offset of 25.4mm so if you're looking at a set with an offset of (-24)mm that's going to be about 2 inches farther out.
Assuming you have a 4th gen 1500, they'll fit. Might look a little odd to have that much offset and a 10 inch wide wheel with a little 265/70 tire on it.. but everyone's got different taste maybe that's what you're going for.
Sunmerk
