Will this work?
Marrapode
5.7L HEMI V8
I'm not the best when it comes to wheel and tire combinations. Had a piece of rebar blow through my tire on the highway today, so I figured it's time for an upgrade now haha. If someone could help me out that'd be great! Thanks
MOTO METALMO962
Size:
17x10
Offset:
-24mm
Backspacing:
4.606"
Bolt Pattern:
5-139
Rec. Tire Size:
265/70-17
GENERAL GRABBER A/TX
Service Description: 115T
Load Range: SL
UTQG: 640 A B
Max Load: 2,679 lbs
Max Inflation Pressure: 44 psi
Tread Depth: 14/32"
Tire Weight: 44 lbs
Rim Width Range: 7-9"
Measured Rim Width: 8"
Section Width: 10.7"
Tread Width: 7.2"
Overall Diameter: 31.6"
Sent from my SM-G975U using Tapatalk
retired
montana
10” wide wheel seem kind of wide for a 265 tire
Marrapode
Marrapode
5.7L HEMI V8
I did a tire and package set up online and after choosing those wheels I picked those tires and it's saying wheel range for the tire is 9" so I'm just confused
retired
montana
Just my opinion but it will look like a tuner car ie not good on a truck. The tire manufacturer says it is too wide trust them.
tron67j
Maryland
If you want to know options, one idea is to call TireRack, they can help with different size tires and give you some ideas of pros and cons for each.
BOWERSFJ
Uniontown OH
7” tread on a 10” wheel .... Please, no !!!
Sunmerk
