Marrapode
I'm not the best when it comes to wheel and tire combinations. Had a piece of rebar blow through my tire on the highway today, so I figured it's time for an upgrade now haha. If someone could help me out that'd be great! Thanks
MOTO METALMO962
Size:
17x10
Offset:
-24mm
Backspacing:
4.606"
Bolt Pattern:
5-139
Rec. Tire Size:
265/70-17
GENERAL GRABBER A/TX
Service Description: 115T
Load Range: SL
UTQG: 640 A B
Max Load: 2,679 lbs
Max Inflation Pressure: 44 psi
Tread Depth: 14/32"
Tire Weight: 44 lbs
Rim Width Range: 7-9"
Measured Rim Width: 8"
Section Width: 10.7"
Tread Width: 7.2"
Overall Diameter: 31.6"
Sent from my SM-G975U using Tapatalk
MOTO METALMO962
Size:
17x10
Offset:
-24mm
Backspacing:
4.606"
Bolt Pattern:
5-139
Rec. Tire Size:
265/70-17
Load Range: SL
UTQG: 640 A B
Max Load: 2,679 lbs
Tread Depth: 14/32"
Tire Weight: 44 lbs
Tread Width: 7.2"
