Could be air coming in between the windshield and the top of the A-pillar trim...Anyone notice wind noise at interstate speeds? My 18 has significant wind noise at interstate speeds. Even worse on a windy day.
‘18 1500 Laramie Longhorn Southfork CC 4x4
Sent from my iPad
Would you mind providing a little more detail on this? What noise were you hearing? What weather stripping did you use and do you have any pics of the install/finished product?Also the mirrors,I popped mine off and put weather stripping around and it helped a lot.
Yes my 2018 with only 3700 miles has annoying wind noise at highway speeds , can’t figure out why or where it comes from. Going to dealer for first oil change next week and will ask them to check it out . But expect to hear “ it’s normal “
Had the first oil change today and talked to the service writer about wind noise , she had one of the techs check all the weather seals, he found a small tear above rear passenger door and will order a complete replacement seal for that door under warranty. Will update again after seals are replaced and see if that helps eliminate some of the wind noise. Very happy with this service department. Schicker in Washington, Mo.
My 18 bighorn sounds like the window is cracked at highway speeds. It has been to the dealer 6 times for the issue. I have had new weather stripping put in, new window seals, doors realigned, chrysler even did a "star campaign" which means they ask the engineers what the next fix should be, and they don't have a clue. it is the most irritating thing to listen to driving down the road. It is almost to loud to even hold a conversation with the passenger. Ram customer service is the worst! They tried to fix it 6 times because there is a problem, now they tell me its normal because the next obvious repair( new doors, dealer recommended) will be to expensive. Between the wind noise, and the ****** uconnect radios horrible sound quality and bluetooth connection, I dont enjoy driving my truck.
If you find anything out please let me know, i am very interested.
