THRobinson
- Apr 19, 2018
- 167
- 11
- Location
- Zurich, ON (Canada)
- 2003
- Hemi 5.7l
So... over a week ago I hopped into the truck and started it up, wipers were frozen and I had forgotten to turn them off the night before and the passenger side wiper made a thud and stopped working.
Finally snow cleared up on the weekend, looked and the inside of the wiper arm all the way in, the teeth are smooth. I looked at the knurled shaft on the truck and the top edge is smooth. Spring clip is still fine but once on it does nothing.
I took a strip of aluminum foil, 3/4" wide and maybe 8" long, wrapped it around the shaft, put the arm on and worked for 3 days, then quit again.
Never seen a wiper arm like this before, kind of a stupid design compared to most. The spring clip doesn't hold it in square enough once the wiper is on the glass.
Debating if I need a new arm, or would the shaft damage it? or because the top edge of the shaft is smooth, it won't matter if it's a new or old arm anyways. From what I can tell, you can't replace the shaft without replacing the entire assembly. Only other thing I can think of is drilling a hole through and adding a screw.
Any ideas?
I did see a video of someone removing the arm and needed a screwdriver to open the clip, I will say mine is still springy, snaps shut on it's own, but no where near tight enough that I needed a flat head screwdriver to pop it open.
Any ideas?
