Wiper Delay
04RAM_3
CA
I just bought a 2019 Rebel. Fantastic truck except the wiper delay does not work. High and low speeds are fine, just no delay. Any suggestions on where to start diagnosing this to fix it?
Adamcr68
Lorton VA
Hemifever 5.7
I can’t offer much help, if any really, electronics are at the bottom of my knowledge with our trucks.
Is your truck a 04’? Not sure if that’s 2nd or 3rd Gen. but you might get a quicker response there.
Hopefully a member with more experience/ knowledge will respond this weekend, my guess would be the contacts worn out in the switch for the delay’s since still working low & high speed.
Don’t know if you tried searching the issue here, you might find someone that had the same problem & how they fixed it.
markabby
Monticello, Kentucky
2020 Limited
From AI:
On 2019 Ram trucks, if the wiper delay (intermittent) isn't working—but high/low speeds do—the most common cause is a faulty multi-function switch (turn signal/wiper stalk). Other culprits include a failed Power Distribution Center (PDC/fuse box) relay or a faulty windshield wiper motor. Check the 30-amp F25 fuse first.
  • Check Fuse F25: Ensure the 30-amp fuse (number 25) in the engine bay fuse box is not blown.
  • Reset Wipers: If they are not parking correctly, try running them on the first delay notch for a few cycles.
Note: For 2019 Ram 1500 Classic models, the Body Control Module (BCM) dictates operation, making thorough diagnosis with a scan tool recommended before replacing parts.
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
From AI:
Hell even on a Saturday school is in session
Thanks markabby
not that I am having problems BUT you you learn something new everyday here
AWESOME Group here
04RAM_3
04RAM_3
CA
Thank you for the reply. Any idea how to gain access to the switch? All the videos show how to get the big plastic cover off. I have a telescoping wheel and the cover is different, and has a boot going to the dash. I cannot find any screws to take out to remove it
04RAM_3
04RAM_3
CA
Hi. It quite literally in the first line states I just bought a 2019 Rebel :)
RamDiver
Marlborough, Ontario Canada
2021 DS
Try searching YouTube for 2019 Ram multi-function switch.
I found the following video for 2011-2018 Ram 1500.
BTW, I've had the panel off below the steering wheel more than a dozen times and never bothered to disconnect the hood release. I don't see the point.
Or search the threads using the search utility in the upper-right corner.
04RAM_3
04RAM_3
CA
I searched and searched video. The first one I watched is the one you posted. I don't have that housing to remove. Mine is rounder, and has a boot in the front that goes to the dash. I cannot find any screw holes in it to get it apart. I didn't see a reason to pull the hood release either lol
RamDiver
2021 DS
Have you searched the threads here?
There are several covering the troubleshooting and testing of the multi-function switch. I don't recall if the complete R&R was discussed or not.
04RAM_3
04RAM_3
CA
I have, and haven't found anything about my specific cover. Looks like this
RamDiver
2021 DS
If you can't locate anything suitable on YouTube or using the search utility, another couple of options are;
Visit a local stealership parts department with your VIN. I've had dealerships print off drawings for cars and trucks, and rarely paid a cent. Some charged a tiny fee for prints.
Visit your local library and find a suitable Haynes or Chilton's service manual. I used to borrow them from the library, and if you find one that's helpful, locate your own copy using the ISBN.
Magfan2
Montana
Amateur, but I was amazed by the wipoers on my 14 - has your windshield been replaced? Ex low and (I think high) mine reads what hits the windshield and responds automatically. Spooky at the beginning.
RamDiver
2021 DS
Good suggestions. Thank you
You're most welcome.
I've been looking at several PDF service manuals, but have yet to find one with a telescopic steering wheel.
I did watch one YouTube video of a '21 Ram truck, and the multifunction switch appeared to be part of the clockspring assembly. It wasn't a very good video, and the mechanic was only describing the R&R process without demonstration.
I will keep sniffing around for more answers.
JayLeonard
6.7 L Cummins
Last time I had an issue with wipers was on my 2005 Dodge 1500. I added an additional ground from the battery neg to the chassis under the hood and everything worked fine again for years.
04RAM_3
04RAM_3
CA
I don't have automated wipers
04RAM_3
04RAM_3
CA
Figured it out. The steering wheel must be removed to gain access. Then it comes off pretty simply. Might as well replace clock spring and everything while it's apart. Thanks for the replies
