Wiper Issues
racerx909
Montana
Hello. Looking for some help/suggestions on how to troubleshoot my wiper issue. Wipers were frozen and they were left on. The passenger side broke loose, but the driver side did not. Now when I turn on the wipers, the passenger side works normally but the driver side does nothing. If I try to move them by hand, the driver side moves freely with no resistance. Where should I start? Thanks in advance for the help.
Silver Goose
Alma,Arkansas
2018 2500 Larame Longhorn
Cummings 6.7 Diesel
Sounds like the linkage is broken, you may be able to see the link from the outside and looking in through the cowl screen.
If one side is working I don't believe it is an electrical problem.
Good Luck
Larry
TatertotScott
The man, the myth, the legend, the one and only!
La Center/Amboy, WA
Wiper transmissions pop off fairly easily in certain vehicles. I would check the transmission connector bushings. Auto parts stires often carry them for $5 or less.
Sent from my SM-G892A using Tapatalk
gofishn
Iowa
hemi 5.7L, 345 cu in
gonna bet it is one or the other but let us know which it was.
R
racerx909
Montana
I wasn't able to get to the parts store tonight to get a battery terminal puller to pull the wiper arms off. Both wipers are working now, but if you apply any physical resistance against the driver side wiper arm, it stops. The linkage underneath the cowl continues to move, so I'm assuming something in the connection between the wiper linkage and the wiper arm is messed up. Do you guys know if there is a replaceable bushing between the arm and the linkage?
Dinky
Oregon
There is a few. Best bet check a dealer they probably have them is stock. They are will have a diagram to show all the parts
