Wiring Harness - UConnect 3.0
jbsmithram
Hi,
I have my old Uconnect 3.0 that I thought I'd turn into a workshop satellite radio. But I need a harness to plug into the back and the pinout diagram so I can power it.
Anyone happen to have either? This came out of a 2014 Crew - no alpine, no 8.4 touch screen.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
This is a 2015 base radio schematic. Should still be the same for your needs.
  • AUDIO-SYSTEM---BASE.pdf
J
jbsmithram
Thanks - is this the pin diagram? I'm not sure I know how to read it properly...like what part on the diagram is the pin?
I don't have a harness on the head unit right now so I just have the hole in the back of the unit with all the pins so I can't go by wire color.
Thanks again
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
Jimmy07
^ That’s the pin out you’re looking for.
Here is the connector... https://www.moparpartsgiant.com/parts/mopar-wiring-52-way~68225148aa.html
Then you would need the correct pins, and also the satellite Farka connector with antenna. Sounds expensive for a stand alone workshop radio, if that’s the way I understand you want to set it up.
I would just get a Bluetooth soundbar and run satellite radio off your phone app.
J
jbsmithram
Thanks everyone - yeah that connector is going to cost to much for this project. I do have all the other parts laying around - FAKRA connector, external satellite antenna and a 12v power supply (old server psu).
I'll keep looking around to see if I can figure out a cheaper way to power this thing up - not worth the $170 connector...can probably buy a radio for that.
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
Junkyard would be your cheapest bet for the connector.
Steve58
