WIRING HARNESS
Ramman70
Ramman70
Coshocton, Ohio
I got the harnesses. Thank you. Neither one of these has the plug in connector that actually plugs into the ABS CONTROL Module. I need that one too . The connector needs to look like the old one attached.
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi,
Sorry I was away last week.
In post #3 I stated the harness is part of the dash harness part # 68430633AB , Did you order this harness?
- Benny
AllMoparParts.com
- Benny
All
All
68430605AC 68334100AF 68430571AD
These are the ones ordered
You need 68430633AB which is the first harness we discussed, Please look back at post 3. Attached is a PDF that confirms what your looking for as well.
- Benny
  • 68430633AB Connector Details.pdf
AllMoparParts.com
- Benny
All
All
No Problem,
I listed them all below with their functions as discussed previously
68430633AB Main Harness for ABS control Module
68430571AD Front ABS sensors
68430605AC Left Rear ABS Harness
68334100AF Right Rear ABS Harness
- Benny
Ramman70
Ramman70
Coshocton, Ohio
Is there anyway you can check on order #717772? Wanted to know when it will be going out..
Thanks so much!
Ramman70
Ramman70
Coshocton, Ohio
Can I take the bolt out and pull the middle part out? I need to get the new cable in and take the old one out. No room to get them out.
Thanks so much!!
Bethel
Ramman70
Ramman70
Coshocton, Ohio
Can I take the bolt out and pull the middle part out? I need to get the new cable in and take the old one out. No room to get them out.IMG_4997.jpeg
AllMoparParts.com
- Benny
All
All
Hi,
Yes but you may need to loosen the other body mounts as well to gain enough clearance.
The harness is due in tomorrow, Hopefully we can get it sent out then as well.
- Benny
Ramman70
Ramman70
Coshocton, Ohio
Benny, I have the 68430633AB harness just about done. Pretty hard one. Do you have a schematic or detailed drawing Of this one? I have a couple connections that I can’t place . The dash board.
Thanks for your help..
You better send Benny a bottle of whiskey for all his help, ;) :Big Laugh:
AllMoparParts.com
- Benny
All
All
Hi Bethel,
I am sorry but nothing that I have already posted. The way the schematics work is we need to first identify the component and then we can search the wiring and its connectors. If you have some components in mind that you think they may be let me know and I will post them.
Out of curiosity was the original harness missing or burned?
- Benny
