Wiring Question
mvfd474
Milton, WV
I just purchased 4 Feinex Cannon Hide a way strobes they are three mode so you can replace your for example reverse light bulb with the HAW and have an emergency mode and a reverse mode when in reverse my question is this
Which is the positive and ground wires for the High Beam (quad lights) and the reverse light?
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
Ground wire should be the only black wire in the pair. You are going to have to pull out a multimeter to test the others and test the ground just to be sure. Don't guess with electrical...
mvfd474
mvfd474
Milton, WV
I figured that that is what I would have to do
Molon Labe
joshhhh
